Mike V. Florida
This seems to be the year of the new old engines. There is a group that just finished casting and machining a 1918 Engine.
Have you ever done a 3-cylinder Zekeley radial? Years ago, a good friend was trying to rebuild one for a 1920's vintage single seat monoplane. He was unable to use the original cylinder heads because the skirts were cracked with missing pieces. He ended up selling all the parts to a local enthusiast who somehow rebuilt it all, but he was unable to fly it (6-7, 260) and couldn't find anyone else who felt brave enough. I've seen it run on the ground & taxi, though.
What changes/improvements have you designed in that are above and beyond, but different from what Henry and Edsel had in the original motor? Obviously the steel can be better, but are there design/philosophy changes that they probably would have made with 85 years of experience and billions of engines made worldwide, but weren't evident when the plans were laid down almost 100 years ago?
Fascinating. Please post pics here when you have your masterpiece ready for public consumption!
Thanks for the pictures Tod, your project is coming along nicely and looks like it will be in the marketplace soon. You have certainly covered all the bases with the machining options you have mentioned so there will be something to fill every need. Smart marketing, my hat's off to you and I'm envious too. I wish I had half your knowledge and ambition.
Tod,
I have read through most of your posts on your engine project. I could not find anywhere where you stated where you got the dimensions / specifications for the engine. Did you measure existing blocks? Did you use original Ford blueprints ?
Bob
My block has pressurized oiling, thicker casting walls, and the capacity for adaptation to stock A babbitt style, insert bearing style, AR cam style, 5 main style, and B crank style. It can be made in aluminum for all of those versions as well as the capacity to alter the waterjacket for no block ports to accommodate the guys that want OHV heads. In short, the variations possible will be determined by the market.
Hope that helps.
Tod
Tod you have likely answered this a thousand times somewhere, and the question probably begs the answer, but here goes....do you feel your engine will run noticeably smoother than many of our rebuilds? Those of us fortunate to have heard an original low-mileage engine are always amazed at how quiet and smooth they are.
