New at this. 1930 Model A 3 window Murray
kyleskott
Best to take a look accompanied by a knowledgeable Model A owner. "Good running condition" can cover a spectrum of faults.
Do the doors sag when opened? Fordor sedans have a wood based body and if the wood is bad you have a major problem. I can only get your small pictures and they aRe not large enough to really view the car.
That $10,500 asking price is in the ball park. He's not overpriced from what the pictures reveal. Good Luck with your decision.
And Welcome to the barn! Jeff
Hope these help
I was told there is some rot on front quarter panel and a rust spot on one of the fenders. With that knowledge, is the price still in the ballpark? I can see the rust spot on the back fender- doesn't look like a big deal. Just worried about the rot, even though the pics look clean. Thinking about offering $8k and going from there if it runs well. Any idea how much to restore a rotten quarter panel? Thank you again for the input
Most folks in the A hobby are DIY so best ask some local body shops about cost to repair rust if you are not able to work on it . 8K is a realistic offer IMHO but in reality the market determines the value. Both ebay and the MAFCA (classified ads) can provide you what folks are asking.
BTW its a wonderful hobby-good luck.
Some thoughts on value.
Assuming you just want a fun reliable to drive play toy and not a points show car.
WOOD. It is a wood frame as you have been warned. Open the doors and see if they are loose. Pull up the carpets and look at the condition of the sills. Go under the car and look at the condition of the sills. The sills are the base frame of the body and what you can easily see.
Mechanicals. Ask questions about who did what. If they show you receipts that the engine was built by a known good engine builder then major plus. If not then assume you will need to get the engine rebuilt at some point. Take the JS with you and if a lot of the car is wrong then assume they did not pay much attention to details in building the car. Is there rust dust coming from the springs, perches or other bolted areas. That indicates stuff the needs to come apart and be fixed.
Look at the front brake levers are they angled forward some (15 degrees)? If it is vertical then you know something is not right.
How is the front axle. Can you see about 1/2 of it when you look from the front. If you can not see the axle and the shackles are pushed way out then you know the spring is bad.
Does it have shocks? Do the shocks actually work?
Driving...
How does it drive. It should feel comfortable to drive at 55 or above. When you stop on the brakes at speed it should stop confidently. Remember it is drum brakes and will take more effort then the 2 toes your modern disk brake car takes.
If the car does not have shocks and does not feel like it is going to jump off the road once you get above 25 MPH then you know the suspension needs to be rebuilt.
How bad does it vibrate. It should not vibrate a lot.
Can you talk to another person in the car while driving. Do not laugh. I know of a professionally rebuilt car that was so loud you could not converse. They professional put used pitted bearings in the ******.
If it is only a 45 MPH car then you know it needs around $10,000 worth of work to become a safe reliable car. ($6000+ for the engine, a few thousand for brakes plus what ever else you find on the way).
Some people may differ on my fact based comments. They have a right to their opinions. I grew up with A's and they were always run 55+ with stock drive lines.
Your pictures don't really show very much. What does the engine look like? Undercarriage and front end? Shocks, brakes, and springs? Steering play, wiring, tires, glass, and radiator? Etc.
If I were looking for a four door, the price you have mentioned and what pictures you have provided would have me looking closer. However, I would think that given the price, there are some issues that need to be addressed with this car. Try to find out what they could be.
Good Morning Kylescott, even with some rot, paint blemishes etc.... The car is complete.
Hopefully it is an excellent runner. How long has the current owner owned this car?
The car appears from the pictures to be in reasonably good shape. That being stated, it is a Fordor, making it a little more rare, and desirable, if you travel with friends/family.
You first offer is reasonable and fair. Do not insult to current owner with really lowball offers.
All this being said. Have you ever driven an old car?
These old cars take a certain skill to drive. Alot of patience is in order. They do not handle the same as modern cars from the 50's.
As to the cost of repairing the paint/rust. Many of us have resolved ourselves to enjoying our cars age spots/blemishes. Patina is in style!
Just make sure its a good driver.
Good Luck ! Jeff
Good Luck ! Jeff
Thank you!!!
Thank you!!!
Thank you!!!
Driving...
Thank you!!! That is alot of valuable info!!! I know about sagging doors and boards, but your other points will help me a great deal.
