The 29 had alot of raised areas on the paint from lack of attention during the tack rag process last time it was painted. Been using a combination of filling up with lacquer, leveling and then air brushing. Seems to be doin the job, it is what it is. The belt around the bottom of the top needed the most attention, it will crack again but probably not as bad as it was.
Thank you Sir. Was lucky enough to get a serious runner with no pending mechanical issues attached. Shes just taken alot of time to clean up after sitting for ten years. The interior needs to be completed now, Ive got a box of interior trim pieces I haven't even looked at yet.
