SteveB31
At $3000 with crank, rods, main and rod bearings , I think that is a bargain. You add crank gear, cam gear, cam, valves, guides, springs, oil pump, head studs, gaskets etc, and your head, valve cover etc, oil pan off your old motor and you have a complete 5 main inserted engine for under $4000- sounds like a bargain- if that price holds out It is a good buy in my mind. Only time will tell.
