The first thing to think about is how badly are they oxidized? If they truly are pitted, then I wouldn't run them . . . find other sets. Yes, I know they're expensive and hard to find, but if the bearing surfaces are compromised, then they will build up heat - which is what ruins bearings and journals.
If you believe they are good, then use a fine pad of 3M Scotchbright and lacquer thinner. You should just lightly scuff/polish them - you should not be trying to remove pits due to oxidation. Once I'm done with this, then I use a very fine paint polish (for clear coats) and a cotton rag and hand polish them as much as possible.
If these are rod bearings for full-floaters, then you need to prep both sides. If you're setting up full-floater rods/bearings, then you also need to "tune" the bearings to they are concentric in the rod bores and float between the rods and crankshaft as they should. This involves a big rubber hammer and a block of wood - and knowledge and patience.
If you want me to check them out - drop me a few close-up and in-focus pictures.
Good luck,
B&S
