Need some help with the 31cowl area
saints
Ok Im stripping and teating rust on my 31 coupe my questionis How do you remove the stainless trim that runs up and over the front of the cowl is there clips or bolts??
pictures would be great as im a visual learner
I have some books on there way I just dont want to sit and wait on them to finish what im doing
On the inside of the cowl , near to the bottom you'll find one nut on each side of the cowl . ( close were the front bolt to chassis is ) if you take them out the cowl band will come off. Good luck,
Gerard
The cowl band has threaded rods at each end with a nut. Follow the band to the end and feel in the inside corner of the cowl, you'll feel the nut. Pretty easy to get off. My problem was getting the back hood bracket off. Mine mounted over the cowl band and the nuts on the underside kept turning in their keeper.
Gotcha man that sucker was tucked in there.... took me a little to get the cowllamps off....love that rust
