We brought home a 28 sedan model a. It did not come with a key. At a local swap meet we bought a brand new ignition set. The car has not run in over 45 years atleast and were learning as we go.
We replaced the old ignition with a new one from a a local swap meet. When the key is in either direction we can get the car to turn and have spark both ways? 1 post went to the dizzy, the other key post went to front of the coil as shown on a schematic.
should this be doing this or not? what did i do wrong?
Another problelm we are having is a drain on the battery. We installed a new battery and cables. We cranked the car enough to drain the battery, then hooked up the charger and it charged to 6 volts. When we attempted to crank it again, it only cranked 2 times. When we test it with the volt meter it reads 6.18 volts, but it will not crank. Whats the deal?
Here's what we've done: New 6 volt battery, new positive and negative cable for battery, new wiring at junction box (same gauge), new ignition, re gapped spark plugs, emory all contact points, re did TDC timing, we have spark from all plugs.
need a little help with this, what are your suggestions or comments. Thanks. Just trying to get her going once again
