pat in Santa Cruz
properly set in the motor mounts, the engine slopes to the back 3 degrees. This slope encourages the oil to run back. There is so much flow in there that it runs over the dams and over into the cam gears as well. The oil also runs around the dams through passages created by the cover. Look at the cover and observe the gasket surface. The dams are only gasketed partially up from the bottom of the cover. A passage way is created between the dams and the cover for the oil to run back.
BTW, ta loud clacking sound is also typical of a sticking piston. Its a loud sound, similar to a rod knock or a very loose tappet, but its usually louder than a tappet. The usual culprits are 3# and #4 pistons, which stick on the cylinder walls between the two. If this is the case, you will see piston deposits and /or scoring on the cylinder walls. Its most common on a new engine that's getting hot, but it can happen to one that's normal operating temp too if the coolant flow to the back is poor or obstructed or of the engine is being loaded too heavy prior to breaking it in. ( e.g. driving too fast).
