Need Set 1936-41 221cu .040 Over Piston Rings
Barn Junk
Richland
WA
Trying to test and maybe save a 37 motor that many years ago had some welding in the lower inside pan rail and a sleeve installed (thrown rod at one time?). The rest of block looks OK but don't want to invest too much in it. The bore is plus 40 thousands and I have some NOS mis-matched pistons (3 and 4 ring), good used 36 LB crank, bearings and rods that I can run but need a set of 3 1/16 +.040 rings to put it back together and test. Found .030 and .060 but no .040s. Anybody got a set of rings to sell or where are they available?
This block was repaired, run and then stripped so wonder it it is usable or has problems.
