Need pro built 36 steering box or 37
Chucks363window
I have a beautiful 36 3 window coupe with a worn out steering box, i would like a pro rebuilt original box , any know where i could get one? Thanks Chuck
You might want to check over on the HAMB with NealinCA. He rebuilds boxes but don't know if he has complete boxes available.
You ought to be able to find a good ‘36 box on the cheap, but for the work involved, the smart move would be to hold out for a ‘37 upgrade.
A word of caution: Don’t start dismantling your steering before being schooled on methods.
When using a 37 box for your 36, make sure you get the frame bracket for the 37 box as the one for your 36 will not work....ALSO, I believe you will find you have to drill one hole as one mounting hole doesn't line up.
You asked about pro-built, here you go.
Lares Corporation, premium steering components
800-555-0767
www.larescorp.com
Did one of mine -- best ever and labeled for pitman arm and filled with John Deere grease.
Oh yeah --- lifetime warranty
