Mike51Merc
I wouldn't be so quick to blame the switch. If you're only getting 5V out of ignition switch---- how much do you have GOING IN to ignition switch? What else is connected to the ignition switch (answer-- everything but the lights and the horn)? You could have a parasitic draw from just about anywhere in the system.
I'd spot check the entire system for voltage drops, moving from the battery forward.
