howie123
I am nearing completion of a Model A speedster. The engine is 1928, and old rebuild. The carburetor is a Zenith that I rebuilt. The gas tank is behind the seat and gravity fuel feed was not adequate for going up hills. I installed a low pressure in-line fuel pump which caused the engine to idle very rough. I then installed a regulator. The regulator came pre-set at 4.7 psi. I adjusted it down only by watching the fuel flow. I blieve the carburetor is running rich as there is a light coat of black soot on the spark plugs. The engine oil has remained clean. I made a sight gauge for the carburetor which shows the fuel level to be 1 in. below the mating surfaces. I have no gas gauge so I calibrated a did stick. It appears I am getting about 16 MPG. I have done most of my driving at 30-35 mph. Today I took a drive and at about 40 mph I heard a couple of small backfires from the area of the muffler. I readjusted the GAV from nearly closed to about 1/4 turn open. I readjusted the spark to 6 clicks or about 2/3 of the way down. I gradually increased my speed to 40-42 mph and it seemed to run pretty good. The temperature held at about 170 most of the trip but when running at a constant 40 mph for about 5 miles it did get up to 190. How hot is too hot? I think I am getting close to having a good running Model A. Any suggestions on a systematic approach to fine tuning would be appreciated. Thanks. Howie
