modela-carb
I need a 13/32" deep socket for my carburetor work. I've tried all the usual hardware sources and looked on-line with no luck. Anybody got a hint for me?
What is the catalog # for a 13/32 deep socket in the Brattons catalog. I cannot find it listedBratton's also carries this.
Use a 10mm 6 point. Works fine.
These guys list one:
http://www.steritool.com/tools/sockets.htm
I guess I should have told you that a little material needs to be removed from the inside like you did with your end wrench. I used a diamond impregnated tool in my dremel. Doesn't take much. Tools are available at Harbor Freight.John, the 10mm 6 point socket does not work...at least the Craftsman model from Sears does not. I'm currently using a 10mm open end that I filed out to fit but I'd rather find a deep socket if I could.
I lucked out! I was trying to collect enough of the old 9/32 drive Snap-ons to put together a good set of wartime vintage. One little box contained a variety of differing length deep sockets, and revealed 1930 and 1931 date codes when cleaned...I eventually realized that they were an actual Snap-on Model A carb set, with special length deep sockets for the several hex headed jets and a 13/32 for the GAV. Having a perfect purpose-made socket for each part is an astounding luxury!
I have not checked the current SO online catalog, but I do know that SO made deep 13/32 in 6 and 12 points at least into the WWII period, and 9/32 socket stuff of that time is fairly common.
