wbedwards
I am having a random miss on what is probably a bone stock '59 Edsel with the 361 FE engine. It cranks easily and runs fine most of the time but occasionally gets a random miss most often from coast to moderate to hard acceleration. It idles fine at 500. It missed at idle one time bad enough to load up the muffler and blow it out when it fired.
I was shooting for the easy things first. In the past 10 months I had to rebuild the carb and replace the tank. The fuel lines and filter are clean. Replaced the plugs, wires, points, condenser, rotatory button, but not the cap, it looks fine. The coil resistor ohms out good and coil is getting 5.8 volts. The dist primary wire is good. The plugs are mostly brown but a couple are getting some soot on them and the exhaust where it hits the ground in the garage is sooty. The timing is spot on 6 degrees and it has a new spark advance.
Two things bother me:
The spark is more purple-red than fat blue and the compression. I might try replacing the coil next.
I pulled the compression and its low, but not low enough to miss-fire I think but would like your opinion. The factory spec is 180 lbs and my readings are as follows first reading and then with a shot of oil: 1 152/154 2 140/145 3 140/145 4 139/144 5 130/136 6 130/135 7 140/142 8 140/146. Using a infrared thermometer on the exhaust manifold, #4 is running a good bit cooler than the rest upper 189 as compared to the others 215 at idle.
I have put about 1500 miles on it since I bought it and it has not used a drop of oil that I can tell.
thanks ahead for any ideas
