I can rule out firing order because it revs up an runs beautiful with choke almost closed. if I remember right when I had the vacuum gauge on it, it read 16. Timing is set to the notch on crank pulley with vacuum line disconnected
What are some common spots for vacuum leaks on flatheads?
