hey there guys, having an issue with overheating on the newer motor I just installed on my model a.
The previous motor I had, had no overheating issue, and is using the same equipment as the new motor.
After driving about 10-15 minutes, coolant starts dumping out the overflow, and the coolant coming out is extremely hot and steaming. the engine is also extremely hot. I drove it tonight for about a half hour and lost about half a gallon of coolant. Checked the plugs and the oil, no coolant in either, no smoke out of the tail pipe.
heres the info on the motor:
Stock shortblock
weber 2 barrel carb setup
FSI electronic 6 volt ignition
Newer recored radiator (worked perfect on previous engine)
Leakless waterpump (2 years old)
snyders premium headgasket http://www.snydersantiqueauto.com/4590
head properly torqued
Some issues:
Exhaust header leaking (could this heat the head up too much)?
original head that came with the motor had a mices nest in it, did not use this head, put on the one from my previous motor. But, the motor also had some stuff in the water jackets, so I cleaned this out.
Could it be possible that there is a jam up somewhere? I was going to use a pool blower (blows water out of pool lines) to see if something is jammed up. is this okay to do or bad for the motor? I was going to do it on the radiator as well.
thanks guys
Stock shortblock
Some issues:
thanks guys
