I do not know how the clip that connects the lower and upper plates is connected. This will be installed on a new distributor using modern points and plates that came as a “kit” from Mac’s. No instructions.
The clip is about an inch long with a hole on the side and a raised “dimple” on a bent end of the arm. The clip is brass colored. I tried to upload a couple of photos but had problems.
Thanks in advance.
Thanks in advance.
