pgerhardt
Ok. So spent all day working on my tail lights without success. I ordered replacement taillights that were already set up with LEDs. The left tail light had stopped working at all. The good news is that I got that one working working. It was a bad ground. I just ran a ground wire from one of the square nuts holding on the taillight bracket to one of the bolts holding on he rear fender. That solved that problem.
The real trouble happened when trying to set up the turn signals. The setup seemed very simple. There are two wires that come back from the wiring harness - one green, and one black. They are for the brake (upper), and running (lower) lights. The person who had set up the turn signals for my car followed a similar pattern running a green (plastic coated) wire back for the left turn signal light, and a black wire for the right turn signal light. I connected the wiring harness green and black wires to the tail lights (right one via the crossover harness), and I had brake and running lights. Great!
Now for the turn signals. I made up my own cross over wire for the black (right) turn signal wire. Then made up 2 two into one adapters so each tail light could receive both the turn signal wire and the wire from the harness. Then I connected everything up. Now when I put on either turn signal, both tail lights flashed, while the third tail light in my back widow worked properly!! (It’s wires also tap into the green and black turn signal wires.)
Now for the really weird stuff! If I disconnected both the wiring harness wires from the right tail light then both work correctly for turn signaling. Maybe (just guessing here) the LED tail lights require so little current to operate that some is leaking back through the regular harness causing both to flash?? I am beginning to think that with LED tail lights you can’t use them for turn signals, and I should go with separate turn signal lights in the back like I have in the front. Without a good idea from our collective ‘model A hive mind” to put me on the correct path, that is the route I will take.
