Need help with horn button restoration
Not George
I,m looking for tips on removing old paint from my horn button, and general restoration advice.
Thanks in advance.
NG
The only way to really do a thorough job is to take the thing apart. With the switch rod removed from the shaft, below the total switch knob are 4 tabs that must be carefully straightened to remove the chrome ring that secures the horn button. After removing the ring, the button will come out (there is a spring underneath).
Then you can refurbish as necessary.
Again, be VERY careful when straightening the tabs, cuz they gotta go back
Merry Christmas
Jim
If that horn button is made of plastic I would consider using very fine wet/dry emory paper and soapy water. It will take some patience and time. Or, perhaps Q-tip and a solvent that doesn't dissolve plastic, like kerosene or gasolene. Try a spot on the backside first as a trial run.
NG Be very careful with those tabs because it looks like the button has been removed once before and rotated 90 degrees. See image for proper orientation of V-8 on switch.
Thanks guys
I can get it apart, what I'm really concerned with is removing the old paint and polishing the button to a like new shine with out damaging the part.
I used low odor paint thinner and a Q-tip. Worked slow and not much pressure. I assume these are soy based plastic like the rest of the early Ford plastic. It took a while but all the paint came off.
