I bet you could use steel or aluminum bar and/ or flat stock and make your own bracket that would bolt to the two most forward intake manifold bolts and those two bolts that are lower down on the front of the engine below the intake. Of course, you will have to use longer bolts to install the alternator bracket. Make a pattern out of styrofoam, cardboard or wood (best) and you will come up with a solution.
