Re: Need Help with a Model A thats Overcharging.
I have some CRAZY ideas as to your overcharging problem.
1. The "Box" on top of your Generator is definitely not a Ford Cut-out and perhaps it is not functioning as intended, thus failing to interrupt the output of the Generator as a Ford Cut-out would, causing the overcharging problem.
2. Is it possible that the two wires connected to the mysterious "Box" have been accidently reversed and connected to the wrong terminals?
3. Is the frayed wire on your Generator, shown in the attached picture, shorting to the Generator housing?
4. Would adding a third wire grounding the Generator housing to the frame of the vehicle help?
5. Is the bottom surface of the Distributor corroded and thus preventing a good connection to ground?
6. This is the CRAZYIEST idea of all - your video posted above shows the sparks jumping the air gap you set up........could that possibly indicate that incorrect wiring has caused a reversed polarity i.e. Negative Ground situation?
