need help please on finding tread
model a cliff
i know i read about a rust removal product that would help clean out the water passages in the block by flushing, plus there was a picture of the product, i just can not find it, thanks for any help or ideas on what to use. modelacliff
You will find tread on your tires.:D Maybe you are searching for a THREAD
Sorry, I couldn't resist it..
Is this it?
I've never put this in an engine, but I have used it to de-rust metal and it is next to amazing. This stuff really works. http://www.harborfreight.com/1-gallo...ver-96431.html
Remove rust in seconds without scrubbing. Evapo-Rust™ is so effective it is used by the 4th Infantry Division to maintain the M1A1 Abrams battle tank.
  • Removes even heavy rust completely
  • Easy to use, just soak parts in room temperature solution
  • Requires no special equipment
  • No acids, bases, solvents or other toxic ingredients
  • Will not harm unrusted steel, safe on other metals
  • Biodegradable—can be disposed of safely into sewer
  • One gallon derusts up to 300 pounds of heavily rusted steel
  • Will not affect plastic, PVC, Viton and most paints
Some of the DFW guys have had good luck putting a little tide detergent in the engine and running it. gets nice and soapy and then you flush. I don't think that would get rid of your rust problem.
1930 Cabriolet
1931 Coupe
1931 Roadster
DMAFC / THEM! TX
