Freoway
Hi folks. Have a 1940 Ford pickup with original flathead and 3 speed transmission. I've had the trans professionally rebuilt and am ready to install it. I've got a transmission jack under the rear of the engine so I can alter its angle if need be. I've got the splined shaft of the trans most of the way into the engine, but there's still about half an inch to go. It was difficult just getting to that spot. I just can't get it in the last half inch.
The bolt holes almost mate up, but they are just slightly out. If I try to raise the engine to bring them into line, the trans goes up too (not surprisingly).
Just wondering if there's something I've forgotten or some trick to this. I lubricated the shaft tip with CRC to help it slide.
In case anyone asks, I haven't used any heavy persuasion methods. All I've done is wriggle it by hand. I'm working through the floor. After two hours of wiggling and jiggling, I'm kinda knackered!
Any tricks of the trade?!
Cheers, Lloyd
Cheers, Lloyd
