700rpm
My coupe does not have a correct wiring harness in it. Every wire is black. My headlights are completely scwewy. Can anyone suggest an easy method for tracing down which wire goes to which terminal in the headlight? The switch is wired OK, but by the time the wires get to the headlights they're all out of sequence. For example, when I turn on my parking lights, I get both headlight and parking light; same when I go to high. And nothing on low beam. These are TwoLites, but there are only two wires (each) going into the headlights. I can figure that part out, I think. But the rest? Ay-yi-yi-yi-yi!
