flatheadmurre
I'm a little out of my depth here, but this is an interesting subject. The thing that occurs to me though, is that it is an offset of the cam lobe to the lifter centre that promotes a rotation in the lifter. The radius may be a red herring as far as rotation is concerned. If the cam lobe wiped directly across the centre of the lifter it would not want to rotate. Offset that wipe area and the lifter will receive a little rotational push every time.
Mart.
This i agree with fully !
And valve rotators has nothing to do with lifter rotation, they promote uniform heat, wear and deflection of the valve and helps keep the seat clean from deposits.
So not a bad idee to use them in my book.
The weight difference between rotators and non rotators are 3g so more to be gained from hollow lifters for weight.
And that they should break....they are used with the same design on heavy diesels with lot´s of more springpressure then any race flathead ever is going to see.
Then when it comes to mixing parts...lot´s of ways of doing it...not only one way that is correct.
Most of the time personal taste is what descides....
