rhoadesm64
Wanting some advice on wither I should just clean out or rebuild the carb on my truck.
The truck starts up and runs fine, no dying and no cutting out. When you press on the gas peddle it just spits and chokes out and the truck stopping running if you let it, if you release the peddle it goes back to idle. It does not matter how long you let it warm up.
I am thinking it might just have a bit of junk in the carb as I can see stuff in the sediment bowl. I did remove and clean out the internal carb filter but it did not have much in it.
Also, can I add a fuel filter somewhere to better protect the carb from ingesting this bad stuff from the tank.
Thanks
Thanks
