Tom Bellfoy
I'm working on an A-V8, converted it to hydraulic brakes using a Ford (I think 42-48) spindle set , put in a Vega steering box, both spindles connect well together with their tie rods, however when I tried to insert the tie rod end for the drag link the taper is reversed on spindle, meaning the tie rod end has to be inverted. I just have the clearance as it would interfere with the wishbone. Any suggestions ?
Thanks
Thanks
