54 Merc Wagon
New member
- City
- Harbor Beach
- State
- Mi.
I am adapting a pair of Granada spindles to fit a 54 Merc for the disc brake set-up. I am looking to: borrow, rent, buy, or swap for a ball joint/ steering arm tapered reamer, to ream the lower ball joint hole of the Granada spindle to fit the 1954 ball joint stud. The same reamer can be used to ream the steering arm hole, to fit the 1954 tie rod end. My thought was maybe someone else has done this swap, and may have the correct reamer. Reamer would have a 1" large dia. tapering to 7/16" small, with a 4&1/2" inch flute length. I suppose it could be a different length, as long as it is 1&1/2"inch taper per foot. ( ps, first time posting, hope I got it right ) Thanks in Advance...
