Idaho Brett
I'm resurrecting my family's Model A and the engine has a "bad" Rear Main Leak. I don't know the "full" history of the engine so I don't know if it has Babbitt Bearings or Insert Bearings.
My questions are ....... After dropping the Oil Pan, can I remove "just" the Rear Main Bearing Cap (by itself) to see what might be causing the leak and make sure the Rear Main Oil Drain Tube is not screwed in too far; as well as finding out which type of Bearings I have?
If so; is there anything I should look out for? I'm not familiar with Babbitt Poured Bearings.
Thanks
Thanks
