Chris Marshall
I'm building a 32 roadster that was disassembled in '57. The body has been moved around a lot since then without benefit of being bolted to a frame. I'm looking for the measurement between the top iron tabs to be sure the rear quarters just behind the doors are not bowed out.
Another idea would be any means to check trueness of the rear door jambs from the subrails to the top of the door jamb.
I'm not sure that there is any problem, but I'd like to be sure.
A couple pics of the roadster:
