wbedwards
This is from a '59 361 V8 FE with 99000 miles on it. I bought the car Jan of 2015 and changed the oil and filter then. I did add a zinc additive also. I have put about 1200 miles on it since. The more I drive the car the better it seems to run and the motor has gotten very quiet with no lifter noise.
I decided to go on and change the oil since it was looking really bad. The oil plug has a magnet in it and had a small amount of deposits on it similar to what you would see on the oil plug from a differential just not grey but black. I decided to cut the filter open and found a good bit of crud inside that is mildly magnetic. My question is, is the HD oil cutting 57 years of built up carbon and crud out of the engine and would this crud have metal deposits in it? I plan on changing the oil much more often until this crude stops showing up.
thanks in advance
thanks in advance
