The only modern stats for 32 to 48 Fords that work in hot weather are from Bob Shewman gadgiteer@aol.com. G.M.
As stated in other post, stick em' in a pan of boiling water and compare them when the valves are open.
The 12% sounds good but if you calculate the area of the openings you will find it to be more in the 25% range not counting the severe restriction on the brass one, then it looks more like 35-40% if not more.
My calculations were as follows:
For the Brass stat: 12.5 mm radius X pi (3.14) = 39.25 sq mm
For the Stant: 14 mm radius X pi = 43.96 sq mm
The difference in area is 4.71 sq mm
That difference of 4.71 sq mm is a 12% increase over the Brass stat's area.
Did I miss something to get to your 25%?
Area= Pi X R squared
Good work.. So the Stant no. Is 14157 when ordering. What is it 160, 170,180?
Might try getting some through rockauto...
A 160 deg stat is not better than a 180 deg stat. Just the opposite.
