N.O.S. Model T Ford parts
Marshall V. Daut
Davenport
Iowa
Price
varies
N.O.S. original Ford parts: Handbrake pawl, $12.50; T-2696 spindle arm, $20; T-2562 brake shaft lever, $3.50 ea.; '09-27 spindle nuts, $3.50 ea.; '09-25 fender eye bolts, $7.50 ea.; '19-27 spring perch, $45; '09-27 crankshaft bolt & nut assembly, $2.00 ea.; '26-27 steering gear drive pinion assembly, $35; T-2597-C differential pinion gears, $15 ea.; '11-27 manifold clamps, $3.50 ea.; manifold stud, $1.50 ea.; T-2597-B 10-tooth drive shaft pinion gear, Ford script, $125; T-2562 brake camshaft levers, $8.50 ea.; T-3428 transmission slow speed notch, $18; transmission clutch spring, $25; T-3427 slow speed shaft, $7.50; T-3315 triple gear pins, $5.95 ea.; T-2591 drive shaft thrust ball bearing plus two T-2591 retainers, $30. Shipping extra. Norm Miller, Davenport, Iowa, 563-322-8388 or 563-320-2096.
