n.c. title
I am guessing "nc" stands for North Carolina. But why do you need a title from 28 to 31; that makes no sense to me.
The car can only be from one year. If you want any replies to your request; you are going to have to provide more information. For instance, why all four years (which wouldn't be possible)? Also, what does North Carolina require for titles (have you check with the DMV)? Is this for a car that does not have a current title?
If you are trying to "build" and title a car in NC now, you are going to be up for a tough time. NC has really tightened up title requirements for antique cars. If you are trying to build a street rod, or a custom built vehicle, they do have other title classes for those vehicles now. Please explain what you are trying to do and I will do my best to give you my opinion of your best way to try to legally do what you need to do.
Don't waste your time trying to use any of the title sales companies as NC will not honor those titles any more.
i'm going to use the title on a rat rod thats why the year only has to be close i've built several cars and know how to title them it's not that tough you just have to keep a paper trail. I have a 1918 titled as a 2010 custom i just would like an old ford title and by being N.C. they go right through thanks
camo67,
Just be careful if you have not titled one in the last year or so.
They changed the law. Parts of the new law were effective 8-5-09 and parts of it were effective 10-1-09.
I am not yet very familiar with all of the ins and outs of the new law. Here it is:
http://www.ncleg.net/Sessions/2009/B...PDF/S820v6.pdf
The text is as follows:
GENERAL ASSEMBLY OF NORTH CAROLINA
SESSION 2009
SESSION LAW 2009-405
SENATE BILL 820
*S820-v-6*
AN ACT TO CREATE NEW MOTOR VEHICLE TITLING AND REGISTRATION
CATEGORIES FOR MOTOR VEHICLES CLASSIFIED AS REPLICA VEHICLES,
STREET RODS, AND CUSTOM VEHICLES, AND TO MAKE CORRESPONDING
CHANGES.
The General Assembly of North Carolina enacts:
SECTION 1. G.S. 20-4.01(43) reads as rewritten:
"(43) Specially Constructed Vehicles. – Vehicles of a type required to be
registered hereunder not originally constructed under a distinctive name,
make, model, or type by a generally recognized manufacturer of vehicles
and not materially altered from their original construction.Motor vehicles
required to be registered under this Chapter and that fit within one of the
following categories:
a. Replica vehicle. – A vehicle, excluding motorcycles, that when
assembled replicates an earlier year, make, and model vehicle.
b. Street rod vehicle. – A vehicle, excluding motorcycles, manufactured
prior to 1949 that has been materially altered or has a body
constructed from nonoriginal materials.
c. Custom-built vehicle. – A vehicle, including motorcycles,
reconstructed or assembled by a nonmanufacturer from new or used
parts that has an exterior that does not replicate or resemble any other
manufactured vehicle. This category also includes any motorcycle
that was originally sold unassembled and manufactured from a kit or
that has been materially altered or that has a body constructed from
nonoriginal materials."
SECTION 2. Part 3 of Article 3 of Chapter 20 of the General Statutes is amended
by adding a new section to read:
"§ 20-53.1. Specially constructed vehicle certificate of title and registration.
(a) Specially constructed vehicles shall be titled in the following manner:
(1) Replica vehicles shall be titled as the year, make, and model of the vehicle
intended to be replicated. A label of "Replica" shall be applied to the title
and registration card. All replica vehicle titles shall be labeled "Specially
Constructed Vehicle."
(2) The model year of a street rod vehicle shall continue to be recognized as the
manufacturer's assigned model year. The manufacturer's name shall continue
to be used as the make with a label of "Street Rod" applied to the title and
registration card. All street rod vehicle titles shall be labeled "Specially
(3) Custom-built vehicles shall be titled and registered showing the make as
"Custom-built," and the year the vehicle was built shall be the vehicle model
year. All custom-built vehicle titles shall be labeled "Specially Constructed
Vehicle."
(b) Inoperable vehicles may be titled, but no registration may be issued until such time
as the License and Theft Bureau inspects the vehicle to ensure it is substantially assembled.
Once a vehicle has been verified as substantially assembled pursuant to an inspection by the
License and Theft Bureau, the Commissioner shall title the vehicle by classifying it in the
proper category and collecting all highway use taxes applicable to the value of the car at the
time the vehicle is retitled to a proper classification, as described in this section.
Page 2 Session Law 2009-405 SL2009-0405
(c) Motor vehicle certificates of title and registration cards issued pursuant to this
section shall be labeled in accordance with this section. As used in this section, "labeled" means
that the title and registration card shall contain a designation that discloses if the vehicle is
classified as any of the following:
(1) Specially constructed vehicle.
(2) Inoperable vehicle."
SECTION 3. G.S. 20-70 is amended by adding a new subsection to read:
"(c) The notification and registration requirements contained in subsections (a) and (b)
of this section regarding an engine change shall be required only if the motor vehicle into
which a new engine is installed uses an engine number as the sole means to identify the
vehicle."
SECTION 4. G.S. 20-4.01 is amended by adding a new subdivision to read:
"(15a) Inoperable Vehicle. – A motor vehicle that is substantially disassembled and
for this reason is mechanically unfit or unsafe to be operated or moved upon
a public street, highway, or public vehicular area."
SECTION 5. G.S. 20-53 reads as rewritten:
"§ 20-53. Application for specially constructed, reconstructed, or foreign vehicle.
(a) In the event the vehicle to be registered is a specially constructed, reconstructed, or
foreign vehicle, such fact shall be stated in the application, and with reference to every foreign
vehicle which has been registered outside of this State, the owner shall surrender to the
Division all registration cards and cards, certificates of title or notarized copies of original titles
on vehicles 35 model years old and older, or other evidence of such foreign registration as may
be in his possession or under his control, except as provided in subsection (b) hereof. After
initial review, the Division shall return to the owner any original titles presented on vehicles 35
model years old and older appropriately marked indicating that the title has been previously
submitted.
(b) Where, in the course of interstate operation of a vehicle registered in another state, it
is desirable to retain registration of said vehicle in such other state, such applicant need not
surrender, but shall submit for inspection said evidence of such foreign registration, and the
Division in its discretion, and upon a proper showing, shall register said vehicle in this State but
shall not issue a certificate of title for such vehicle.
(c), (d) Repealed by Session Laws 1965, c. 734, s. 2.
(e) No title shall be issued to an initial applicant for (i) out-of-state vehicles that are 35
model years old or older or (ii) a specially constructed vehicle prior to the completion of a
vehicle verification conducted by the License and Theft Bureau of the Division of Motor
Vehicles. These verifications shall be conducted as soon as practical. For an out-of-state
vehicle that is 35 model years old or older, this inspection shall consist of verifying the public
vehicle identification number to ensure that it matches the vehicle and ownership documents.
No covert vehicle identification numbers are to be examined on an out-of-state vehicle 35
model years or older unless the inspector develops probable cause to believe that the ownership
documents or public vehicle identification number presented does not match the vehicle being
examined. However, upon such application and the submission of any required documentation,
the Division shall be authorized to register the vehicle pending the completion of the
verification of the vehicle. The registration shall be valid for one year but shall not be renewed
unless and until the vehicle examination has been completed.
(f) If a vehicle owner desires a vehicle title classification change, he or she may, upon
proper application, be eligible for a reclassification."
SECTION 6. Part 3 of Article 3 of Chapter 20 of the General Statutes is amended
"§ 20-53.3. Appeal of specially constructed vehicle classification determination to Vehicle
Classification Review Committee.
(a) Any person aggrieved by the Division's determination of the appropriate vehicle
classification for a specially constructed vehicle may request review of that determination by
the Vehicle Classification Review Committee. This review shall be initiated by completing a
Vehicle Classification Review Request and returning the request to the Division. The Vehicle
Classification Review Request shall be made on a form provided by the Division. The decision
of the Review Committee may be appealed to the Commissioner of Motor Vehicles.
(b) The Vehicle Classification Review Committee shall consist of five members as
follows:
SL2009-0405 Session Law 2009-405 Page 3
(1) Two members shall be personnel of the License and Theft Bureau of the
Division of Motor Vehicles appointed by the Commissioner.
(2) One member shall be a member of the public with expertise in antique or
specially constructed vehicles appointed by the Commissioner from a list of
nominees provided by the Antique Automobile Club of America.
(3) One member shall be a member of the public with expertise in antique or
nominees provided by the Specialty Equipment Market Association.
(4) One member shall be a member of the public with expertise in antique or
nominees provided by the National Corvette Restorers Society.
(c) Members of the Vehicle Classification Review Committee shall serve staggered
two-year terms. Initial appointments shall be made on or before October 1, 2009. The initial
appointment of one of the members from the License and Theft Bureau and the member
nominated by the Antique Automobile Club of America shall be for one year. The initial
appointments of the remaining members shall be for two years. At the expiration of these initial
terms, appointments shall be for two years. A member of the Committee may be removed at
any time by unanimous vote of the remaining four members. Vacancies shall be filled in the
manner set out in subsection (b) of this section."
SECTION 7. Sections 3 and 5 of this act are effective when this becomes law. The
remainder of this act becomes effective October 1, 2009.
In the General Assembly read three times and ratified this the 28th day of July, 2009.
s/ Walter H. Dalton
President of the Senate
s/ Joe Hackney
Speaker of the House of Representatives
s/ Beverly E. Perdue
Governor
Approved 2:03 p.m. this 5th day of August, 2009
Being a NC used car dealer I can tell you that anything that age will usually trigger an in person inspection by a DMV Inspector. It has gotten a whole lot tougher to get old cars titled in NC in the past year. If it does not appear 100% stock then expect problems.
All of my antique cars are original or restored to original, and I have no experience with Street Rods or Customs. While I have no experience with what they are looking for on a Street Rod, it will require a visit from a DMV Inspector.
I know people with legitimate antique autos who have had major difficulty obtaining titles under the new law.
I JUST WENT THROUGH ALL THIS WITH MY SPEEDSTER. It is not easy even with all the paper work. It took over 3 months to get it done, then in the end you will have to get inspected every year to get a plate.
