Mystery trunk back pans
karasmer
Trying to solve a mystery of two different trunk pans for 29 roadster, the yellow one has the trunk latch riveted on and the blue one is bolted, it is also an inch wider but the same length, thinking yellow is for trunk setup and the blue one is for a rumble setup, or ???
I think you are right, the yellow one is a trunk inner panel and the dark one appears to be a rumble curved inner panel. There should be no latch parts riveted or bolted to the curved inner panel (dark one). The latch should be on the top of the rumble lid/rain gutter. There are 2 different styles of inner panels, the shorter one for 28/29 coupes and cabriolets and a taller one for 28/29 roadsters and 30/31 coupes & roadsters.
Rusty Nelson
The yellow one is for:
A-45203 Pan (floor) Rear Assembly…Rear (Mid) 1928-29 Coupe Models​
trunk assembly;
and the blue one is for: Rusty is correct!
Pluck​
Can you show a photo of the trunk latch on both panels? I am still questioning the blue panel.
Pluck
The latch on the blue one is bolted on , an obvious add on, weather a replacement or conversion from rumble to trunk? I would also think that as far as trunk models go wouldn't the roadster and the coupe use the same pan?
Depends on what year...
A-40203-A Pan (floor) Rear Assembly 1928-31 Roadsters and 1930-31 Coupe Models​
A-45203 Pan (floor) Rear Assembly…Rear 1928-29 Coupe Models​
Pluck
