Bruce Adams
On Saturday my starter did not respond to the starter button AT ALL.
I Hit the "starter" with the headlights on and there was no dimming. I figured that meant the switch so I popped in a new switch and no change in results. I then popped the plugs and turned the shaft with my crank wrench with no particular restrictions.
I brought the starter to ANTIQUE FORD PARTS on Long Island and Bob Bader put six volts to it and it jumped to life.He felt it had jammed, causing the problem.
He returned it to me, I replaced the starter and it works perfectly for twenty starts in the past two days.
WHY, if it was BOUND, would the lights NOT GO DIM?
Thanks for your opinions
