Dyna
Went for a bit of a drive the other day, after about ten miles I felt a slight hesitation, drove on and it got worse to the point that I had to pull off the road.
Checked under the hood and everything seemed OK. Tried to start her up, would not start until I choked it. Was able to get home. Revved it up in the driveway, running rough, backfired and blew black smoke out the pipes. Today I checked and cleaned the fuel filter. Started fine, let it warm up, bumped the throttle a bit and heard a strange "pop" , revved it a bit more and heard more "popping". I thought it sounded like it was coming from the carb. Pop is intermittent.
Engine is 1951 V8 1CM fresh rebuild, carb fresh rebuild, fuel pump new, plugs and wires new. Anyone heard this before? Thanks
