Check your private messages again.
Marshall
Why keep sending private messages?
We all benefit from each others experiences and shared knowledge.
If you have something to say, please just post it so we can all benefit from it.
They do sell ball hones that small, specifically a company in California called Brush Research. I bought some from them and I am waiting on them to come.
I verified it was an intake valve by watching the engine run with a valve cover that has the top half cut off.
Interesting, i have not heard of the cut valve cover before.
1: Did it stop the oil splatter?
2: How high up did you cut the cover?
I ask because I need to do the same thing, but instead of cutting a cover I will make one from sheet metal.
Chris, I am sorry you are having so much problems. In my mind, the only thing that makes sense is a sticking lifter. Unfortunately fixing a sticking lifter will require some work. You will have to take the pan off and remove the cam. You can keep the lifters up with cloth pins. You will have to remove the valve keepers and springs.
How have you determined that the lifter "works fine"?
The only other thing that I can think of is to use a heaver valve spring on that valve. I assume you have checked the spring. You could take the heaver spring out after a few thousand miles. I have stretched springs to increase the spring force.
Update: still have the sticking valve. Mechanically it does not make any sense as the guide has plenty of clearance for the valve, a different valve and spring were put in with thr same results, and the lifter works fine. I am unsure of where to go from here as I have run out of ideas and gotten sick of tearing the engine apart after 4 or so times!!
