Mystery ‘37 85hp engine bolts…help
snappydon
So as I’m organizing my parts and pieces for my 1-1/2 ton, I have these 2 bolts (actually 4 but I have mixed parts from 2 engines) that I can’t figure out where they go.
Any input is really appreciated. I don’t want to put something together and tear it apart again.
I’ve had the timing cover and pan off to replace the soft plugs in the pan rail. I suspect they go there somewhere?
Re: Mystery ‘37 85hp engine bolts…help
Stepped shank bolts like that are special bolts for sure. I've seen similar bolts for hinge applications. Maybe a 37 Ford owner can nail them down for you. Most flathead V8 engines use same or similar bolts no matter the year and I certainly can't recall engine bolts like that.
I'm not even sure now that they're from the '37.
This project got stacked into a pile and moved to the side of my shop, I'm really frustrated trying to sort and identify things.
Gotta love helpful family.
"I'm not even sure now that they're from the '37.
"This project got stacked into a pile and moved to the side of my shop, I'm really frustrated trying to sort and identify things."
Try putting a 35 peecup together, that never was together. My truck is assembled from parts gathered from all over the country, even a couple of parts from NZ.
No parts from the same vehicle except for maybe running boards.
They are definitely not from a flathead engine. They look similar to the bolts that allow the top to pivot on my ‘37 convertible sedan, but those had a slotted screw head not a hex. Therefore, you have a mystery bolt(s).
