My wide-bed
Jim Brierley
Got my '31 widebed up and running for the first time in 8 years. Built a new lower end in '13, ran it about 20-25 miles and blew a head gasket. I believe the problem was too long head bolts, they bottomed out. Added an extra, thick, washer to cure the problem. Engine is a 1936 4-port Riley, A block, B crank with welded-on counterweights, Weber DCOE carb (side draft), Brierley cam, Mallory dist. Truck has a B trans with Zephyr gears, Colombia diff, hydraulics, 4" dropped axle. Compression is back up to 180 lbs. on all 4. A little tune-up on the brakes and look out world, here I come!
Curious about the Weber side draft. Pictures? Did you make the manifold? How does it compare to the 32/36 down draft?
Dennis, I made the manifold myself, and it looks it! I can't seem to post pics on this forum, but will take one if you'll send me an e-mail I can send you one.
My Son and I visited Jim last week, as always a Big Smile and tall stories!
Fired up the pickup, it sounds really good. He just wouldn't let me drive it, He must know something I don't.
I am sure soon the vineyards' will be echoing the Riley song and Jim will be smiling!
John
