DennisR
Originally I had a noise when I pressed the pedal. The general opinion was probably a knackered release bearing so I decided to replace the whole clutch. When I got the old one out there was no obvious reason for the noise that I could see, but I went ahead and changed the whole clutch anyway. All put back together and on testing I still have the noise. Took it apart again, checked everything, I could see what the problem is. I put it back together yet again and I have recorded a vid of the sound as best I could, the engine running I press the clutch gently using my hand until it contacts the forks and slowly increase the pressure, the sound starts off as a mild scraping sound and increases to a quite heavy scraping sound is the best way I can describe it.
https://youtu.be/ZapFe7OtZUo
