lh
This is a 1930 and not many miles on a rebuilt engine. It had a knock noise for about 15 seconds at start up then went away. I pulled the oil pan off and there was no filings or metal in the pan, nice and clean. I checked one of the rod bearing that had the most "play" and plastigage was 0.0015". I did not check any other bearings because of no metal in the pan. But the rear drip tube is not tight and has slight movement and has some weld at the threads? Also the oil pump has a 1" crack in the housing probably from a screw to hold the pump in when it was reassembled. I could not remove the slotted plug from the side of the block, too tight.
So the plan is to use the old pump with the crack? Then do nothing with the drain tube, leave as is? I will live with the oil leak. I will wait for forum input before putting the oil pan back on.
