yachtsmanbill
OK... so thats a Holley "Hot Plate" Vaporizer carb. Theres a tin plate under the part with 4 bolts. That has hot exhaust on one side and gasoline being heated on the other. That tube with solder is under vacuum and mustve leaked. I believe there used to be some type of packing nut to seal it, but ol' Bubba mustve fixed it with some solder (or lead). That needs to come apart to replace the probably rusted away tin plate.
The throttle arm is on the left of the pic and the choke arm is just below the bulbous air horn towards the bottom. Typically, those carbs would start on a small gas supply, and after good and hot switch over to kerosene... so the story goes. If the exhaust threads are shot, put it on ebay IMHO...
The block and hogs head are definitely an "improved" model engine. Open the cover and verify that the brake band is wider than the low and reverse bands. Again, at this point, it is what it is...
Get yourself a $100 digital camera with a 8meg memory card and take lots of pics... way better than a cheat sheet with notes LOL... ws
