My new project 1928 Ford!!!!!
frenchy dehoux
Now that I have my 1932 Hot Rod Lincoln done it is time for my next project. Here are a few pictures of this project. I will be installing a 1953 Ford Flathead with a pair of Mercury heads a 1952 Mercury transmission 3 speed with 16 x 4 smoothies wheels in front and rear. Also pictures of the engine.
Frenchy
Nice project, is that a driver side 28 29 roadster door? I wonder if it is surplus to your project. I need one real bad for my flatty powered 29 roadster project. PM me if it is for sale. thanks Rich.
Actually I do have another V12 and was thinking of putting one in but I figured a Flathead V 8 would be cool. I will post pictures as I get into this project.
Frenchy
Very cool project. I'm working on a 28/29 Roadster Pickup with a 39 toploader and a 53 EAC Merc flathead. I wish you luck.
JMKnight, Bountiful, UT
How about a custom fabricated intake with six strombergs, maybe just two or three that really work. Rich
This is the engine in my 32. I think a V8 in this one will be easier and much cheaper to build.
Frenchy
Here are pictures of the transmission I will be using. It is from a 1952 Ford and I recently found an early Hurst shifter to adapt for this project.
Frenchy
Here are a few pictures of my recent find a Hurst shifter a friend had this on his shelves and was kind to sell it to me.
Thanks
Frenchy
It has been a while since I posted on this side of the forum. I have made some progress on this project slowly but shurely. Pictures are showing where I had to shorten the floor board due to the fact that this body was narrowed and shortened as well. Also this past weekend I was able to do more work I had located a pillar post from a 1929 Briggs which I had to slice in half so that one piece would be use for the left side and the other for the right side and would be welded to the rear quarter panel. Both rear quarter panels were made out of the two rear doors and both were shortened down to 12 inches in width. As you can see from these pictures.
Thanks
Frenchy
Here a few more showing progress.
Frenchy
