My Fiddy Three
willitsprout
Well, the time has come to post some pics of the Sunliner. Dug out of the dirt in Fresno, and drug it home, According to the scale had over a hundred pounds of debris in the car. Last run in 1969. Has a EAB but I got lucky, no water in the crankcase. Well here's to ya!
Two years I've been playing with my Merc, I have accumulated a bunch of extra parts,and have learned quite a bit (won't say I have accumulated knowledge) about these flop tops.. anytime I can help,,let me know.
Thanks all!
Merc, using 180 grit polish.....
It'sa, just learning about all this...
Working on a couple of stuck valves right now...
BUT if someone has a extra 2X intake I would be interested...Yea Ha!
wga, actually Turners..I think it was one of the last complete..w/engine and trans. I even scored an overdrive, but I understand there is a clearance problem with the solenoid.
The drop tops with overdrive had a special rocker plate that bolted on and mounted the operating solenoid in a different position utilizing a rocker arm to actuate the pawl into the balk ring. This positions the solenoid down underneath the transmission instead of sticking out the left side. If you have an X member frame, you will need one of the solenoid addapters. I've seen several fabricated set ups on the HAMB that work just like the OEM assembly does so if you can't find one then one can be fabricated.
