RandyMettler
Hello,
My 1950 8ba is anything but what Henry Ford originally intended. For better or worse it is compiled of different parts from different year motors. My dipstick reads full with 3 quarts of oil and that's with priming the oil filter. How many quarts should the 8BA block take? I have heard 5 quart and 4 quarts. I need to scribe by dipstick. Oil level is important and I would like to make a decision based upon a few senior members educated speculations, realizing I do not have a stock setup. I do not have the top mounted oil filter. My filter is screwed into the bottom driver side of the block, don't know if that matters or not. I have the 8RT truck oil pan with the large clean out. I imagine that could matter. The engine could in fact be a 8rt but I am not sure. I have the 24 bolt pattern, only the head bolts have been reverted back to head studs and nuts. My pistons are .080 over but don't think that should matter much, just slightly larger engine displacement.
Regards
Regards
