My 56 Ford leaks ****** fluid in low range
Old Redneck
If I run the 56 in drive the ****** doesn't leak but if I shift in low range it leaks a steady stream of fluid. What the proglem with the ******?
If it does the same thing when you floor it and cause the passing gear to kick in, I would guess that means control valve passage is clogged so fluid pressure has no where to go except back out the front pump seal. Not sure.
