Trailerparkhardware
Hello,
I am having trouble with my 1941 Ford Sedan. It is not running as it should. I have been working on it for a while but I have not been able to get it right. Here is where I am. It is a 1941 Ford Sedan it has a 21 stud flathead V8 in it which I believe is a 1938. I have done a 12 volt conversion on the car, rebuilt the carburetor, and installed an electric fuel pump. It has new plugs and wires. and I have done an external coil conversion. It also has new water pumps. The problem I am having is that when you step on the gas and hold it wide open it only revs up to about 3500- 4000rpm and then starts to sputter and the RPM don't climb from there. I hear popping from the exhaust but I am not getting any back fires out of the carb. The car starts up right away and idles smooth with the choke on. I have noticed that even after the car is warmed up if I open the choke more than half way it will stall. I can turn the idle screw in and increase the idle speed and keep it running but still if I hold the throttle open it will climb to 4000prm and then start sputtering and not climb any higher. I have checked a few things and done a little to rule out some possible causes. I check the compression on all cylinders and found the following:
Cylinder 1: 90psi
Cylinder 2: 95psi
Cylinder 3: 95psi
Cylinder 4: 98psi
Cylinder 5: 100psi
Cylinder 6: 100psi
Cylinder 7: 100psi
Cylinder 8: 100psi
I pulled and checked all the plugs and they are all black, not wet but black. I have only idled this engine and never driven it as I still have the front sheet metal off that car. I have disconnected the exhaust from the manifolds to rule out a clogged exhaust system. The fuel pressure going into the single 94 carburetor is 2psi. I have rechecked the wiring and plug wires and believe them all to be in good shape. The points seem to be properly adjusted. I don't know what is holding this engine back. I am not sure how to do timing on this type of engine since there are not timing marks. I will continue to search past threads for answers on that. However if you have any suggestions on what might be causing my engine trouble I would love to hear from you.
Thank you for your time.
Tom
Cylinder 1: 90psi
Cylinder 2: 95psi
Cylinder 3: 95psi
Cylinder 4: 98psi
Cylinder 5: 100psi
Cylinder 6: 100psi
Cylinder 7: 100psi
Cylinder 8: 100psi
Tom
