Steve Plucker
Was the multiple disc clutch pilot bearing the same as that used with the single disc clutch?
Thank you.
Steve Plucker
Thank you.
Steve Plucker
According to Bratton's catalog, the multi-disk clutch did not use a pilot bearing.
No, the multiple disc bearing is A-7580-AR and the single disc is A-7580-B.
You can see a picture at the link.
http://www.santaanitaas.org/wp-content/uploads/2014/08/1B-Multi-Clutch-Restorer-Jul-Aug-2003.pdf
Bob
Your right, I screwed up.Methinks that you're confusing the pilot bearing w/the release (throwout) bearing
On side note:
Bearing 6203 was also used on various IBM machines over the years.
Big green book ALSO shows a pilot bearing page 346 P/N 70-7600-B called "OILITE"
I believe that this might have been a Oilite bushing ...
along with a felt washer P/N A-7608
and a retainer A-7609-A.
Footnote says that felt is "no longer supplied"
I don't want to hijack the thread but my 1930 phaeton (single clutch disc) sometimes slips out of 2nd .I'm convinced it's slackness at the pilot bearing (after having replaced everything else!) Can someone confirm the shaft diameter should be .668 inch dia (16.972 mm) and the pilot bearing is Bearing # 6203, 17mm ID, 40mm OD ,12mm wide.. There seem to various types of 6203 - Rubber seal, metal seal, open, deep groove etc. which type should it be ?
