Tom Wesenberg
You can bolt the starter in place before the clutch housing is installed. That way you can run the starter to check for clearance. You wouldn't even have to run the starter, but could spin the helix forward by hand to check for clearance. If the pinion feels snug at all then change the end plate to the one with the eccentric locating ring.
I'd have to see your armature shaft without the drive in place to know what was done to your starter. Also with the switch removed I could tell if the starter main case was the early or later one. Some people have files down the starter pyramid to be a flat contact.
